How to Install Enigma Silvo Build on Kodi (Firestick & Android TV)
Originally published at: How to Install Enigma Silvo Build on Kodi (Firestick & Android TV)
The following guide shows you how to install the Enigma Silvo Build on the latest version of Kodi. “Enigma Silvo” is a new all-in-one build that can be installed from the Enigma Wizard. This build offers both debrid and free content making it a great choice for any Kodi user! However, for those wanting higher-quality…
Problem: Can’t get any repo’s to install from zip file. Get the message ‘Network is not connected’. Running the latest version of Kodi 21.2 on the Formuler Z11 Pro Max. I have ‘Unknown Sources’ turned on and Update Official Add-ons from any Repositorities selected. Trying to load Kodi build Enigma Silvo, and also The Crew repo. Both give the same error. Not sure where to go from here. Any help would be appreciated. Thanks in advance.
You need to put another / after the word repo. The same thing happened to me. Index of /repo
That shouldn’t matter. I did it just like his video where he doesn’t add the / at the end and it worked as it should. If you click this you will see it still loads the Repo index Index of /repo
More than likely he’s making an error when typing in the addresses for what he’s trying to install.
welcome
I always copy paste everything when installing anything in Kodi as then you will have no errors.
I use the Kodi remote on my phone that connects to Kodi running on my network. You can also fully control Kodi using this app.
You could also get the zip files for add-ons from GitHub and send them to your device from your mobile using an app like atvTools
Either works really well and saves a lot of time when installing add-ons.
Just saying. Copy paste failed for me and I resolved the issue by typing in the info manually. Never tried with using a phone tbh. But I gave up on kodi after testing it again a few months back. I may give the 64 bit kodi a try on this P6L. Love these 64 bit apps. No time like the present.
Wow that was easy to install and authorize premiumize. Nice. Now to kick the tires
What! @Miki you are using KODI? What’s gotten into you? :rofl:
:face_with_spiral_eyes: Must be the meds I’m on. :shushing_face:
Tried that. Same error.
DOGE - Typed it in, double checked, and everything appears to be right. I’m using the instructions from Troypoint ‘How to install Enigma Silvo Kodi Build’ and step 8 is the URL I’m using. I get the error on step 11 after selecting Install from zip file.
Hi, I have a onn tv box. I installed Kodi 21.1 and followed your directions on how to install enigma after I restarted my box I press Kodi app and I get a complete blank black screen. I’ve tried for several hours and nothing :person_shrugging:… Should I try a different version of Kodi maybe?
welcome
Update: Resolved… Had to disconnect and disable Kill Switch on SS VPN before the install from zip file step. After the install, I reconnected SS and enabled the Kill Switch. Works great. Just don’t know why I had to disable SS when others have not had to do that…
So how does this build stack up to xenon all in one?
I’ve just tried using the URL https :// team-enigma. xyz/ repo and it’s not working, says the source cannot be found.
Any ideas or alternative locations to try ?
*Deliberate spaces put in the URL by me to prevent it from being shortened to index of/repo
Hello, double check that you typed it in properly. It’s working just fine and you can see that by clicking the URL and it loads as it should.
https://team-enigma.xyz/repo
If you did type it it correctly, might be your VPN if you’re running one. Try disabling that.
Make it all the way to install enigma wizard, but fail message reads "dependency on script module 0.0 could not be satisfied " how do I resolve?
Hi,
Does anyone know how I can find or add a search function on the homepage to search tvshows etc instead of going in the addon?
