I’ve used the links given still get the same result, right as I try to run Night Of The Living Dead the OOPS! error for Burst shows up. I’m starting to think there’s something else going on. Now my Shield Pro won’t play Kodi or Cinema and the TV it’s hook to now won’t link to the WIFI. I’m completely lost in the sauce
Damn. That’s a nightmare.
Are there video installation step by step guides to correctly install Stremio, Real-Debrid, and many more like them to Kodi. Or aer they in some type of bundle. Also do you have to pay for Smart Mail service, i follow the instructions up till that point then the instructions aren’t mathing up with the options I have to work with.
This is the one I followed to install on some of my devices.
Problem just as stated
try this https://repo.gaiakodi.com
Hey there,
This usually happens because your VPN is active when downloading. Try turning it off and then re-connecting after download has completed.
hi i checked this for him with no vpn and its not working just a heads up for you
I did just try and it worked for me. Maybe a device restart would help.
Would you happen to know how to setup the umbrella app to give checkmarks on viewed umbrella links.
Thanks
Here is an explanation of the setting on Reddit if you use Trakt. If not set to local
https://www.reddit.com/r/Addons4Kodi/s/OqMsq3ZluT
There is a section under Playback where you can set the % to use to mark as watched.
Not really sure if it works as I also use Trakt (its free) as @Avid08 mentioned. It does a great job. Has an app for your phone too. Highly recommend.
Thank you very much, i’ll try those
quick question, when i watch movies on elementum add on, i have it on an external drive along with kodi. i know we download to make the streaming easier and low buffering. my question is, can we delete the download when finished? is the download on the jumpdrive? curious, please advise.
i am getting exact same problem, what is the fix.
all it does is keep on loading and then says timed out. Maybe that is due to all the pop-ups.
I use firestick 4k KODI with Diggz free version the only apps I found are elementum/gratis red/look movie ..many others will say “all in one” including free but seems the free apps do not load
Have you tried power Kodi build it’s one of the best free options on Kodi but usually free diggz works fine too. Onstream, UK Turks, SportzX work well too free but free options are not working as well these days on Amazon devices these days that are updated. I blocked the updates from Amazon using troypoint guide it still works for new Amazon devices as far as I know
