How to Install Elementum Kodi Addon
Have you Authorized RD in Umbrella?
Well if you
-followed all of Troys instructions to install Umbrella and Cocoscrappers
-and the Read Debrid account was paid and authorized to Umbrella under Universal Resolvers2
I dont know why you are still having issues.
Sorry
Can Ip vanish be used with elementum? Its all I have, and cant really afford surfsharks full payment that they require.
I have IPVanish on my laptop and Elementum works on it. :slightly_smiling_face:
Thanks BillyWilliam, I just downloaded Elementum today, works great so far. I have the vpn monitor dot to go with ipvanish. I sure wish they had a kill switch, just in case.
Ipvanish does have a kill switch. I use it on my Nvidia and Onn devices.
The only difference is it is a seperate app. But they work together.
Go to your app store it should be there.
If not let know.
Edit: see if this helps. Its not in playstore but available on Downloader or directly from link below.
Ohhh I never knew that! . Thank you JPM ,ill check it out tomorrow and download it. I am trying this new elementum Kodi setup since I read about the debrid possibly going away. Thanks again :grinning: will let ya know how it goes.
Downloaded the killswitch, works great. Running it with Kodi umbrella.Never knew the killswitch existed, thanks again, jpm!
When i go to download the elementum addon, i get an unknown error has occured. Check your URL and connection. I’ve tried this multiple times with the same notification. Am i going something wrong here, any help, please?
Webpage not available
Webpage at http://files.catbox.moe/mfcjn5.zip could not be loaded because:
Net::err_connection_refused
My son put it on for me last night and it seems to be working fine so far.
Installed Elementum on Troypoint Kodi Fork 21.1. It appears to do everything like it should, up until I choose a link to play. Then, nada. Am I missing something?
I am using Elementum on Kodi 20.2 and it works fine. For me, once I pick a link, it has to load, which takes a little while. The link I picked for the show I am watching, lists all the seasons and all the episodes in a single link. Once I pick the episode I want to watch, it loads and plays. I just watched 2 episodes on Elementum with no problems at all. Not sure what is going on with your situation.
So i turned off killswitch and the surfshark vpn and that worked, elementum addon downloaded successfully
A couple of basics if not tried yet, try update it. Can go into tool settings in Elementum and clear cache and packages, exit, unplug device for 5 minutes. No joy maybe delete and reinstall.
elementum just buffers. Any ideas?
Works on Troypoint 20.
Probably same old, the non-debrid servers can not keep up with demand.
Try choosing a smaller file. Some of those 4K files will buffer due to their huge size and when running a VPN that may slow it down.
I downloaded Elementum from downloader but when I go to file manager in Kodi . Go to external files an then to downloader the file is not their . Downloader is completely empty . Am I doing somthing wrong ?
