Downloaded this and found it rather annoying. Doesn’t play a lot of stuff and when it does it wil play for a second or so and go right back the menu. When it does play something the picture quality is very good though. I guess for those who don’t want to pay for a quality IPTV service this would be something of a choice.
Right Remy, and if you don’t have a debrid service for VOD, it is better than nothing.
Exactly @JerryJ .
I dont complain about the free stuff because well it’s free. Lol I’ve had paid iptv and get frustrated when It buffers or goes down. Not with the free ones though. And I got my debrid for movies and tv so that is all I really need.
The DreamMachine seems to be ready in its newer state. They give a whole list of available features. But I have no idea how to set up the EPG it says it has. Would be really cool to test this out but I dont know how. Anyone?
@JPM69 I have Dream TV but rarely use it. Having said that is there a definitive site for the upcoming DreamMachine that is due to replace it in October? A Google search does not return a clear solution. Would like to see about the EPG for it. Thanks
The old DreamTV had the url to dl the repo
It is
Not sure why the post changed my url but I’ll send it again but put spaces
https:// tinyurl.com / TheL48
I don’t see any settings related to EPG even though EPG capabilities are mentioned in the opening statement.
The free and premium M3U sections are incredibly hit or miss with the premium section being slightly better.
I don’t use the radio section and have no clue what the Stb Mac section is about. Base on my brief testing of this section nothing is playable.
The Xtream section is the only one worthwhile to me. It gives you four server lists and you have to pick and choose which servers you want to access or work best. You will quickly come to realize which servers look and feel like those within the Dream TV addon. A quick hint, in the settings menu, turn the server check mode to show original list. This will eliminate the extremely long check process on every server in each list, thus giving you quicker access to the content.
The Xtream section in my opinion is the only reason for keeping and using the addon at the moment. This section is the only thing that resembles the dream tv addon which actually works decently.
Dream Machine is not working. Any suggestions or substitutes?
If you have a debrid service Umbrella and Fenlight AM are both working great. Do a search here for install instructions
I think that Petey is probably looking for a live TV option, which Dream Machine is purported to be.
I found a working links on Dream Macine. It was “cord cutter” not “kstv” links that worked. When you put the # in to check servers pick it closer to the max number.
If you only check 20 servers as opposed to 200 you won’t get all the available ones to check.
I think this reply makes sense. If not ask me again. Lol
This was tested using xtreme list 2.
Thanks, JPM69,
It worked.
I just installed this addon. PLEASE bring back the original one!!! I am completely lost on this change.
Hey @JerryJ . Yeah its a bit different to navigate.
I dont use it too often but I try to test it out a few times a week.
