Originally published at: How to Install Dream Machine Kodi Addon (Dream TV Remake)
This tutorial provides intructions for installing the Dream Machine Kodi Addon on your Kodi device. You can follow along with our guide using tons of popular streaming boxes such as Firestick, Google TV, Android TV, or anything else compatible with the Kodi software. We recommend one of these devices as they provide 3rd party app…
I was using the Dream TV addon without any major hitches using one of the servers (usually Server 1) provided on the screen. A message appeared at the top of the welcome screen to install Dream Machine addon via the url’s given. I tried this a couple of times but it did not work for me, however, the Dream TV addon continued to be functional. Also both addons were showing in the repository list.
Is there a specific time limit for the Dream TV addon for the transition to Dream Machine, or does the transition require the complete uninstall of Dream TV repository and zip file and then a reinstallation of the repository and the Dream Machine addon. Which I don’t want to do if I am to lose Dream TV and Dream Machine doesn’t work?
There was a pop up on DreamTV stating that after October 1st you should only use DreamMachine.
If your DreamTV is still working it may (probably) be on borrowed time.
The url that you are referring to is not “clickable". It needs to be installed using Troys instructions. It worked last i tried so there may be an issue on your end.
Dreammachine is working but as always, not all servers will work all the time.
Eventually DreamTV will highly likely stop working. If you want to test out Dreammachine before you commit I suggest loading it onto a kodi fork so you know what you are getting.
Good luck and Welcome to TroyPoint!!
What’s interesting is that apparently you can enter Xstream data instead of being stuck with m3u URLs like what’s needed to buse Kodi’s official Simple Client.
Now and then I run into a stream that has no audio and using VLC doesn’t work either. Opening the stream up with Kodi always works so far.
Hi all , so just found out dreammachine won’t work on troypoint fork for k19 just saying error. It’s ok on same Google box , my other fire tv k21.3. Also anyone got a fix for surf shark not working in Canada yet?
Why are you using Troy Fork for kodi19? That is outdated for many addons. Use Troys 21.2 Fork and reinstall DreamMachine. That should work.
Have they released Kodi 21.3 or did you mean 21.2?
Dose anybody know the password for adult content for The Dream Machine kodi addon?
Is Dreamachine down? I’m getting an errer message telling me they are off line. Anybody getting this?
I dont see that right now. Perhaps this had something to do with the Cloudfare outage yesterday.
Also, you are using DreamMachine NOT DreamTV, right? There is a difference.
It cam back up. I guess it was just off line but now Im having trouble with the Sportie addon. An error keeps coming up telling me to update their addon. I did it about 10 times but it still won’t update or pair. Anybody having this problem with this addon?
dream machine & dream stop working ? I get a failed to load playlist .
I have loaded Dream Machine. Everything comes as it should. However, when I click on a channel, It played for about 5 or 10 seconds and the turns off. Ever channel does the same. Any suggestions as to the solution. I have deleted and reload several times without success.
DreamMachine is so big I think you should be a little more specific where your problem occurs. I just loaded a random server and tv show and it plays without issue. I’m using an Onn Pro.
What device are you using?
What server is causing the issue and have you tried others?
I dont use DreamMachine often but can try to help. Its a backup to my backup. Lol
Check your memory .
Just curious…whatever happened to the DreamMachine addon?
I thought that it was kinda cool when I tried the original Dream TV. I had found a TV station in Quebec that played American TV shows in Quebecois French
As far as I known its still up and running.
The issue for me was its too big for its own good. It is not a simple one click and watch. Too many choices and options just to get to a list of channels.
I guess if you are in the mood to look for a specific channel from a specific country its worth the hunt. For me i could get most of what I want from Streamfire or kodi tv addons.
For real the dream machine was money for the longest time up until like a week or so ago, now it’s straight dog shiit. I’ve tried every server from every damn country on all the available server lists one two and three cuz there’s nothing on four, and I can’t find a damn thing to work. The only ones that do actually work kick you off after like 15 seconds of watching maybe a minute if you’re lucky. Any ideas? It would be greatly appreciated LOL
Welcome to TroyPoint @DonCorleone!
I dont use DM anymore but will test it out every now and then.
What are you trying to watch? Have you tried other options like Streamfire or the TV app?
My kodi live tv is used basically just for ppv sports or a baseball game on apple TV only.
Yes, when they made the change over from Dream TV to Dream Machine it all went downhill fast.
This is the nature of KODI for Live TV. Been using it for 10 years but learned that lesson years ago. Do not ever count on it for consistent Live TV. You will find addons that work flawlessly for months maybe even years but they die fast. These addon dev’s are unpaid hobbyists and well life happens. KODI is great for VOD and there are always multiple working great addons for it (Umbrella) but live TV? Not so much
Find a cheap paid unverified IPTV service for your live TV. I recommend Amber Baby’s Strong which I have as a backup to my main service. It is very good
