How to Install Diggz Burst Kodi Build V2 (Non-Debrid/Torrent Links)
Originally published at: How to Install Diggz Burst Kodi Build V2 (Non-Debrid/Torrent Links)
Diggz Burst has officially returned! This ever-popular build is back in the Chef Wizard as V2 after many months of not being available for installation. Our guide features step-by-step installation instructions for this build as well as a detailed video guide with important information that you should know about this streaming option. Diggz Burst is…
Hi,
I installed this build on both a fs 4k max and onn box. However when I choose a movie and pick a link, on both devices, i get kicked out of kodi.
I have uninstalled and reinstalled all from scratch several times, but still result.
I have tried with vpn and without vpn.
Please any advice will be appreciated.
Regards
i can’t even get the zip file to download!..is the url correct???
It looks correct to me. Make sure you type EXACTLY as shown. Use caps/lower case as indicated and no spaces.
Well no caps that is…
https://diggz1.me/diggzrepo
thanks for the answer…i deleted the data in Kodi and tried to download this file to put in there…think i’m going to uninstall Kodi altogether and reinstall…then try to download the file again…now, I have done that…reset my firestick as well…and now it is telling me when i try to download the file, it can not find the directory…what am I doing wrong?..I think the url is changed…i know that can happen.
The Url is fine i just used it the other day.
Did you “Allow from unknown sources” in kodi?
Make sure to follow Troys instructions step by step. If you are new to this it may seem tedious but it will work.
There are plenty of people here to help.
Good luck!
I have always used no limits but couldnt get it with this new setup, i just got diggz burst and it loaded, looks beautiful & im excited about the trakt section cuz its faster but i can not get anything in my list or even the regular lists to play, can someone help me please. I am also running surfshark
This is one of the “free” builds he has so it will probably have fewer links available. Free meaning not using Real Debrid.
Have you tried any movies/shows not in your trakt account?
I highly recommend the Debrid Only Xenon Plus build . I am guessing you dont have a Real Debrid account. Look into it on herefor information and for a nominal fee you get great links all the time. You can use RD on many other builds and streaming platforms too.
Unknown sources is on…I go step by step like I always do…Does this build work with Kodi 20.2, because that is what I have…when I go to add the file source, it tells me: “Unable to connect. Couldn’t retrieve directory information. This could be to the network not being connected. Would you like to add it anyway?”…I am not new to this… but I will say I’m a novice (no expert). I change builds from time to time when they start to get wonky…I have never run into anything like this before, hence the reason why I ask about the url…everything is connected as it should be as far as I know…I would really like to try this build. I hate that this post will only let me reply once every 24 hours.
Not sure why the issue. I have one last check for you.
I only get that message when i input the URL wrong. Can you make sure you are using a : not a ;
My keyboard makes me change the keyboard options to get to the :
All the other letters and symbols are on the main layout.
If you are far away the symbols look similar. At least with my eyes.
And no spaces at the end of the url! You cant see them but they could be there.
Good Luck!
I have the same problema. Double checked for typos. No problems. Confused newby
This same thing is happening to me as well and I know the URL is typed correctly.
What are you using FS? Onn, nvidia etc? I cant explain why its not working for you but if you provide more information maybe someone else can help.
I’ve run into this issue before, and the culprit turned out to be Surfshark. I couldn’t connect to the Diggz server with the VPN on. Turned it off and voila, connected and downloaded fine. Just remember to turn the VPN back on before you start streaming. Hope this solved your problem.
If I have a Real-Debrid account, should I install the other one? Or would it be fine to add my account to the free version? I have been using your website and watched all your YouTube videos before they took your channel down. Those had the best info. Last question, is there ever going to be another Xanax fix repo? That one was the best of all time, in my opinion. I have used just about every build there has been to see if they even come a little close to that one. I just haven’t found one I can still get used to, and that build was four years ago. Thanks for all you do, you’re an amazing tech wiz! Air high five…Oh yeah, so I used your ipvanish discount code about four years ago and haven’t had to pay for it at all since. It says I still have a trial, which is perfectly fine with me. I wasn’t sure if I should allow LAN access outside of the network VPN? And thanks for that code. Or is ipvanish not a good idea?
I use Surfshark as well…so I’m going to try that for sure!..thanks for the reply…by the way, JPM69, I’m using FS.
I am using a Nvidia Sheild and I tried loading the URL with Surfshark disconnected and that didn’t work either. I’m pretty much ready to forget the whole thing.
I was having the same issues, now it’s fixed! It was a VPN issue. Someone suggested to turn off wiregard and switch to open VPN. So I switched to open VPN TCP in features and now everything works great. I was having problems with my IPTV service as well and now that works again too!
For all you Elementum fans, there is a Diggz Build available for you. Not the build I use so this is for informational purposes only. Enjoy!
As it was mentioned there is a definite problem trying to install this with SS invoked. I’ve turned it off for the install and will see what happens once it restarts. Of course my VPN is going back on.
