How to Install DaddyLive Kodi Addon
Sorry to hear that did not work for you. The truth is DaddyLive has always had reliability problems, especially when there is a Kodi update. I’ve seen it working fine, then suddenly not work for weeks, then magically fix itself. I mostly use Mad Titan Sports these days, it is much more reliable and is actually organized MUCH better than DaddyLive. It also has a live TV feature that works quite well. If I find out anything else I will hit you back.
I could tell you to reinstall a bunch of stuff and clean the cache, but the truth is more often than not that does not work.
Thank you!!
KODI is great for VOD Shows/Movies. I’ve been using it since 2016. Having said that IMO it is NOT reliable for IPTV/Live TV, Sports nor should it be. I suggest getting a paid IPTV service for anything Live
I used to think I could get all my Sports Free from KODI addons and at times I did. The issue at hand is these addons are usually run by non paid developers - Hobbyists like you and I. And when life happens and more important things happen the Addons bringing you your live Hockey games do not get updated. After much frustration I moved to a paid IPTV service a few years ago and now only use KODI for those VOD shows/movies my IPTV service doesn’t have
@TP-Brett @Miki looks like you merged my reply into another thread which is fine. But this thread appears broken as my response which is the latest was buried halfway up and older responses are after mine. My reply was a few hours ago and there are posts from 2023 below mine. I usually see the latest responses as the last in chronological order. Just thought I’d bring this to your attention as the OP might never see my reply to their question
I haven’t merged any posts this morning. I just got back from grocery shopping. Let me see if I can find what you are talking about.
Ahh yes I see what you mean. Unfortunately I don’t have admin privileges so I can’t change the order of posts once they have been moved.
@Ohiopatrick317 FYI, I replied to your post but it got merged and buried in the wrong order in this thread. Just wanted you to know
It isn’t burried any more. I put it in your post just above mine.
How do you install Daddylive when I’ve already downloaded Aspire last week? How do you get to Kodi home screen? I’m nee to Kodi…
Install another Kodi fork and install it to that.
Search Is Your Friend...!
Well, DaddyLIve isn’t working at all for me today Getting the “One or more items failed to play” error message on all channels.
me 2. is there a fix?
Back up and working for me.
Hello,
Daddlylive and Loop both addons are not working! soon after 2 weeks you have published how to install them with EPG support etc., both addons are not functioning! any clue?
Just tested both and they are both working for me.
It is possible the one channel or game you are trying to watch is having an issue but the random ones i tested worked.
Just deleted and then re-installed DaddyLive. Still not working. I get the same error message: “check the log for more information”
You’re a genius. Just disabled it and now Daddy is working!!! Thank you
Disable clean web on Surf Shark. Just did it and Daddy is working
You are very welcome!
