How to Install Cinema HD APK on Firestick
Try Onstream in the meanwhile.
Hello, I’m asking for help on my Onn Plus. I ditched my Firesticks last week when they started to block my 3rd party apps, got 4 Onn Plus boxes to replace them. The first 2 boxes set up last week without any hiccups. This week I attempted to set up the last two, but I’m unable to load Cinema from APK Time. The link is there, but when I press the green Download button, it says “Downloading” but it stays at 0% forever. I have given APK Time app the Permissions to Install in Apps, like I did on my first 2 Onn Plus boxes. Have tried several times in the last 2 days with same result. Is that link down by any chance? Is there a new link? Any help is appreciated, thank you.
Hey @Thorpapa , you might want to try the new Beta Release for V4. I have included screenshots for how to download this in our installation guide - How to Install Cinema HD V3.4.3 & Beta V4 (2026)
Thank you! That worked perfect! The Beta version also works as expected…..and no ads :+1:
Downloading streaming services replacing Cinema?
See this for alternatives - 5 Best APKs for Firestick/Android TV (Free Movies & Shows)
Have downloaded Cinema HQ from official site, appears to be a good app. Ran Virus Total which showed 3 infections, including a Trojan.
Google Play Protect immediately disabled it.
I had to uninstall the app unfortunately.
I run IPVanish which doesn’t protect against viruses.
Cinema HD don’t work anymore plus go to the play store an turn off play protect to keep them from deleting your app.
I originally turned off Play Protect but is it worth it ?
@Hawky20 , if you’re ok with googly deciding what apps you install and use on your device, then by all means turn play protect back on …
