How to Install BK Nox Build on Kodi (Firestick & Android TV)
Originally published at: https://troypoint.com/bk-nox-kodi-build/
The following guide shows you how to install the BK Nox Build on the latest version of Kodi. “BK Nox” is a popular Kodi build from the Doomazday Repository that was recently updated and now works great again on version 21 Omega! This build comes pre-installed with top add-ons for streaming on-demand movies, TV series, live…
Decent Build. Loaded it up on the Troypoint 21 Fork. Also nice that the authentication for RD and Trakt only needs to be done once at the Build level versus each Addon
Sounds like that’s Account Manager being used, right? IMO, it’s a must have if you use multiple addons with a debrid and trakt. Makes it so easy.
I cant imagine having to authorize each addon individually anymore.
No. I’ve heard you talking about that with Digzz I think but it’s not Account Manager at least from what I can tell. The Grindhouse Builds I’ve been using for over 6 years are the same. You Authorize RD and Trakt one time and it’s synced across all Addons in the Build. It really depends on how the Dev sets up the Authorization process in a Build
BTW did Alonso save face with that game winning Bomb? :joy:
Gotcha. I’ll have to DL to see how they do it. I am nowhere near being confused as a developer but i can understand if they set up their build with pre-installed addons but how would it work if you added a new addon? Would it recognize the new addon as well?
To be fair, in the build i use the Account Manager only has a list of about 10 addons that are supported but i dont know if thats a build list or an actual AM list. Umbrella, Coalition and other popular ones are there so its fine bc i dont really change addons too much.
As for the Polar Bear… he didnt really need to save face but was struggling/pressing a bit. Turning down 158mil might do that to you lol. The happiest person was Boras… it was an expensive HR but well worth it. Hitting one yesterday was a great sign too, even in a tough loss.
LGM!!
Just Dl’d the build and it does use AM. If you look at the Accounts section you will see Accounts MGR right below it.
I noticed it lists 30 supported Debrid Addons so i guess Diggz only mentions the ones on their build but the others are also compatible.
