Originally published at: https://troypoint.com/batman-kodi-build/
The following guide shows you how to install the Batman Build on the latest version of Kodi. Not to be confused with the Superman build, “Batman” is a newer build that can be installed from the Funstersplace Repo. This repository provides some awesome Kodi builds! The Batman build comes equipped with reliable add-ons for streaming…
For some reason I have some issues when I install a build on my Kodi. Some apps will play fine while others not so much. With add ons I never have an issue everything plays great.
