How to Install AutoStream Stremio Addon (1 Click Playback)
Installed but not sure what it’s supposed to do. It doesn’t show anything when clicked
I would do it on a PC. I just installed again, no issues.
Yep, me too
does this have to be installed using a windows pc because I’m on a Mac and im not getting any streams when trying to use auto stream although it shows in stremio add-on.
I too have found this same issue. I’ve also noticed this add-on is always the last to finish scraping, which I can only attribute to the “embedded” optimization/learning algorithm supposedly happening within its code. In my initial trials, I’ve found that in roughly 7/10 searches, it correctly produced both a 4K and 1080 result (as per my configured parameters), but when I hover over/click either link, the details of the chosen stream are incomplete or are totally absent with the queried data table that pops-up showing all “zeros” and then freezing up.
On a positive note, the times it did function properly and produce the desired results, the “optimized” stream started immediately and played flawlessly till the end of the show/movie.
Additionally, in full disclosure, as I began trouble-shooting and double-checking my configuration inputs, I did find inconsistencies in my saved data, which could possibly be attributed to starting data entry on one pc and finishing on a different pc. Obviously, more testing will be required before I feel confident enough to start rolling out this Kodi alternative to my less “tech-savvy” customers.
In conclusion and IMO, Stremio with a more stable Autostream add-on coupled with the other add-ons installed, is surely going to give Kodi a serious run for supremacy in the VOD apk arena.
I installed this addon today. I opted on the setup to provide 2 links. Well, I tried using it this evening and nothing happened. I tried both links provided and there was no loading and playback. I ended up using Torrentio to play my video.
Same here. Nothing played when I selected the link.
I tested this thoroughly today and ran into the same problem when integrating a debrid service. No links would play. However, if you don’t add a debrid provider, you are still given 2 link options and both play perfectly! Hopefully we see the developers get a fix for this problem in the near future.
yes it is
I chose auto stream that I had setup for 1 title and found a 1080 quality when I played the movie it froze every 5 seconds. I did setup with premiumize. It’s a good add-on to bad it doesn’t work :pensive_face:
So does this compliment or replace my already installed addons like Torrentio?
Followed the information by Troy only selecting the items he showed. On the Last install when Stremo was open, there was a pop-up that asked for a URL. That was not shown by Troy. I closed the pop-up, but did Troy have a different version, or is there a URL to put in to make it work?
