How to Install APKs & Kodi on Android Box
I did a factory reset on my t95n because Cinema quit working and a msg was coming up low memory. I don’t understand all the terminology. I just need to know what I need to do to get Cinema or similar apps installed. As far as I can tell Kodi is not there and I need a downloader.
Please help
These should help get you started again. Use Troy’s Toolbox (also a code) to help with other apks that aren’t available via the downloader codes.
