How To Install and Use Seren Kodi Add-On
Thanks, so Orion works in Umbrella too? I’ll look in Kodi in the Orion add on and see if I can figure it out.
Don’t think you can use Orion with Umbrella but not needed because you have all you need with CocoScrapers.
Umbrella showed in his screenshot, hence, my question. You don’t need Orion with Seren either, there are a gazillion links already. We just get obsessed, just in case :wink: and want as many as possible. Thanks!
Orion links with cocoscrapers if you’re using them.
Thanks for the tip. Orion integrates with a slew of add ons. Seren was already integrated, I added POV, FEN L AM and Umbrella.
Question - No links that I saw actually said “Orion” in them. How do you know if a link is from Orion?
Not sure why they aren’t showing :confused:, they should.
What movie was that? When I watch something later on, I’ll know where to look. I didn’t see anything like that on mine. No big deal but thanks for responding and I appreciate your time.
Make sure in POV, go into settings, scroll down to sources and turn on torrent and hoster settings for Orion. Always remember to click ok before backing out, to save the changes.
