Originally published at: How to Install Alienware Kodi Build on Firestick/Android for Kodi 19 Matrix
The following step-by-step tutorial shows how to install the Alienware Kodi Build on Kodi 19. Currently, the Alienware Kodi Build is one of the few builds compatible with Kodi 19! This build is located in the cMaN Repository, which holds some other solid Kodi 19 builds including Fallout and the Element Build. It uses The…
