How to install Alexa on Onn Android TV Box?
Does anyone know how to put Alexa on the Onn box.
onn is a google product, alexa is amazon
Silk was Amazon but. someone found a way to put it on the Onn box.
I’ve never tried it but I’m told you can download “Amazon Alexa” from the playstore and install it on any Android box with Android 5 or higher.
Will give it a try. Found that Alexa is better than Google assistant.
