Originally published at: https://troypoint.com/fix-widget-binding-failure/
The following tutorial will show you how to fix widget binding failure error in ATV Launcher or Wolf Launcher. Both of these launchers offer an awesome feature that allows for displaying widgets at the top of the screen. Unfortunately, some devices don’t support it and results in a widget binding failure error. One of the…
I have not been successful in getting a Surfshark widget on my Nvidia Shield Pro… even after trying to use Troy’s video multiple times. Any ideas for me?
Hello @jorom on the Shield make sure that you enable both USB debugging and network debugging. I think the Shield is unique in that regard that there are two of those setting that need to be enabled. Give that a shot. Also, triple check you are inputting the codes properly.
Both debugging settings enabled! However, I just installed Monitor Dot from Troy’s toolbox and it is giving me exactly what I want.
This worked on my TCL c655 google tv. However, everytime I reboot my tv I have to go through the steps to get my widget to work. Is there anyway or a step I am missing to not have to input everytime reboot.
Running andriod 12 (Snow Cone)
Explore and enjoy.
I had this working fine but at some point the widgets started not fully displaying properly.
They load but the full UI of the widget is not displayed. For instance with SS “medium” I get the light blue background and disconnect and pause buttons. But now details above the buttons.
Thoughts?
