I’m running Kodi on a firestick using the Xanax build (updated 2020). Can I get some assistance in deleting that build so I can install a new one?
I would just uninstall the Kodi app entirely. It is easy enough (Troy’s ) to install a fresh copy and then use whatever build you want on it.
Just go into your Fire Stick settings then click on My addons then click on Manage installed apps then scroll down to Kodi an click on delet data then click out of settings . That should do it .
This is how I usually do it! lol
Lol:joy:lol. That really made me laugh
Thanks for the replies, looks like there’s a couple options. I already tried the one about starting at the computer and shrugging my shoulders but that hasn’t worked so well lol
That didn’t work this time, it usually does the trick
