Originally published at: https://troypoint.com/create-custom-kodi-build-kodi-widgets/
Kodi users looking for an advanced user interface will enjoy this guide that shows how to design your own Kodi Build by changing the Kodi Skin & adding custom Widgets for a fabulous streaming experience. This is a great way to use all of your preferred addons and customize the home screen to curate the…
Would i be able add pics of my grandkids or any background pics whatsoever as my homescreen?
That’s what I use for a few backgrounds on Aeon Nox Silvo and Fentastic skin. ![]()
Thanks for that great tutorial. Is there a way, once I have it set my way, to save the build so I could install on other devices? Would a fork be the right path, and if so, how do I make a fork?
I have done several custom builds over the years which as you know can take up quite a bit of time with a lot a personal touches. Used to back the builds up with openwizard and create an installable zip file that hat could be installed on other devices, but that is no longer possible with the Onega framework and I have never had any luck with the official Kodi Backup. Any suggestions from others would be greatly appreciated.
