How to change default player in tivimate
i did a search for how to change the default player in tivimate
my search results from the search bar on TP
“how to change default player in tivimate”
No results found.
i just searched this on the site,no results…hey i’m in no way a complainer…i just test
googled it and had a working fix in like 5 seconds
interesting?
i’m also a paid member …you go Troy!
i’m in for the long haul
settings>>>Playback>>>use external player(yes/no)
you are absolutely right ? as i already knew that…kiddo…what about the less informed testers on this site that put that same question in the search bar ? not a good answer for them but google is always your friend
no offense taken…what a great site
I think the issue is, that in order to cover absolutely every single configuration, would take a huge number of posts. Often searches are worded too specifically for individual configurations and information. What I did instead was a search for “TiViMate Manual” where such information, as how to change the player, would be found, and there was over 50 results returned including links that members supplied to those on line resources containing the answer to that specific query.
You did not mention which external player ? Me am going to use MXPLAYER as that seems to be a popular solution for TS files.
