How do you pair RD with Stremio?
I just downloaded Stremio to my PC, but I can’t find the setting to pair it with my RD account. I’m sure it should be obvious, but after messing around with all the settings and menus I can find, I still don’t see how to do it.
Install addon Torrentio
Stremio Addons - Community List (stremio-addons.netlify.app)
You have to configure RD with the chosen addon that you decide to install to Stremio.
In the case of Torrentio, that @Powerfader, suggested you will need to configure the addon prior to install by inputting an API key from your RD account - then click the install.
I configured torrentio, and tried it with two different RD keys, but couldn’t get the add-on to install. After hitting install, what exactly do you need to paste into Stremio? I tried just pasting torrentio but that didn’t work.
Never mind, I’m an idiot. I never noticed the copy link button.
Download the Stremio app to your PC and install everything from there.
Actually, I downloaded it to my PC, and installed Torrentio twice, but it’s still not working. I’ll just have to keep fiddling with it until it works correctly.
Hi Mac6 Hope this helps it what I used make sure you click read more under Torrentio
https://www.reddit.com/r/StremioAddons/comments/v6vwkf/installing_stremino_torrentio_real_debird/
