My tivimate upgraded to a level that is not supported by my older OS on my CM-7600 box. I have 3 of them, so I need to copy from one of my other boxes back to the upgraded box. Any ideas? Plus, how do you make folders on external disk? Thanks!!!
Steve
Send to TV is in the play store, you can copy between two Android devices, I use it between my bedroom and living room devices. I also copy from one device to the other on the same television.
You will want a file system app, I use MiXplore but any should work, copy the file to a directory, download directory works but the app adds a transfer director you can use as well. You can then install.
Tivimate has a built in backup and restore option in the settings. Make sure your current device has the most recent version of Tivimate because both devices have to be on the same version to backup/restore. Save a backup file to a flash drive or cloud storage and then restore on the new device.
I have a backup, but the updated tivimate won’t even run because of the OS level, so I can’t restore from the backup
Thanks. I will give this a try. I have contacted Tivimate and they are going to give me access to my old level so I can download from their webpage as well. Thanks again
