How can I get downloader on a android tv box
You can get it thru the PlayStore…or a browser…
Downloader by AFTVnews
Note: There are several similar looking logo apps…so check out their site to see how it looks…
can’t find it in google store
It tells me its not compatible with this version i need to side load it
Do you have Unlinked or any store/repository like it? Do you have a web browser set up?
Have a look at Troy’s tutorial
Downloader App on Firestick & Android – Install Secret Apps
Forgot to ask…you do have allow unknown sources…verify apps turned off don’t you? Playstore should give you downloader & unlinked.
Type in troypoint.com/dl in your browser on your device enable developer options first and then if a pop-up shows saying to enable unknown sources just click settings on that popup and switch it to on for your browser
yes i have a web browser
Awesome Ty very much
Did you get it to work?
