How can I extract an Android APK from tv stick
Hi. I will like to know how to extract an Android APK from a TV stick? GTV APK Uninstaller not working.
Do you just want to delete it from the stick?
If you simply want to delete the APK from the Firestick, go to the following: “Settings”, then “Applications”, then “Manage Installed Applications”, then scroll down the list of all of your installed applications until you find the one you want. Click on it, and on the right-hand side you’ll see the option to “uninstall”.
If the uninstaller is damaged then log into your Amazon account on line and then go to your apps and uninstall it there, then resync your device and you’ll be g2g.
