The specs look very similar. Same S905X4 amlogic quad core CPU. The same GPU. Which is the better box. I’m not that knowledgeable about all of the details. Thanks
More specific on brands? But yes they are similar as there are many 905X variants but much different under the hood such as ram type, storage and who actually made it. Many boxes are just thrown together with little knowledge and others more android savvy boxes.
Sure cheap for the X4S 4/128. $44 USD I believe. Wow.
The 2 boxes listed are ok but sub par with newer boxes. Both have ddr3 ram which is less powerfull and wired is only 100mb. Still both will work ok, buts thats why the price is lower than normal…call it a clearance ![]()
Is there a better box in the same price range?
whats your limit?
