Help new firestick can't find repositories for promise, oath forked or dynasty
I just received my new firestick max it has 12g but I see less memory then 2nd gen . anyways can’t find respiratorys for promise , dynasty, Genesis and oath forked? Someone reply if you know respiratory for any of above thanks Paddy
Try this https://techecoyote.github.io/Install_LooNatics, found it by clicking on the Magnifying glass at the top of the page. Give it a try you’ll find everything.
Hey thanksi put that in exactly n it’s say can’t connect? All those apps r still working. Troy said warehouse respiratory which is that link if you try it n still working let me know please thanks much just love those addon
My apologies I thought it was a good link! You might try a new add-on called Dradis. Don’t know if you use a real debrid or not there’s a lot of good ones that work only with that. Seren, Fen. Those work wonderful with real debrid. https://tinyurl.com/TWHrepo that’s the address I could find for The Promise. Not sure if it’s a good one or not just search on Troy point for the best Kodi add ons
Oath is no longer available, promise is not updating anymore, use Scrubsv2 for free streams.
I have all of the debrid services thanks Luffy addon just going to stick with old firestick for now
Thanks took ur suggestions it’s just like venom awesome love this site if I can help u folks please reach out happy streaming
Excellent addon old venom thanks alot
