Help jailbreaking
I had old firestick that stopped working. So I ordered a new Firestick and don’t remember how to jailbreak. Can you help me? Help
P.s. I tried ONN but did not like it so I just returned it.
I have a brand new firestick never used 4 to 6 years old. Will it still work and sideload and jail break okay. new to this stuff.
Welcome Ron3033!
Have you tried to use it yet? My guess is it will work and you will be able to sideload kodi and other apps onto it. I dont think Amazon has stopped that yet. But there may be some restrictions.
Just saying its 4-6 years old doesn’t help with the version of the FS. If you can find that out it would help you with questions how to do things. Some versions may have different capabilities. Also, not updating software if possible may be beneficial too.
You may be better served getting a newer non-Amazon device depending what how you plan to use it.
aftvnews.com
is a great resource for Firesticks but don’t forget to use the TP site search. Tons of articles vids etc to read and watch.
stick will work fine on most apps maybe a bit slower but you will be ok
