If this APK will work, it’s laid out AWESOME. Genius, hope it works and stays, experimenting with it today. Thanx for the recommendation
I installed and tested it. No options at all. No way to select your source or whether 720 1080 or any other option. The only accessible option is choose sub language and Auto show Sub. Once vid is chosen it plays reasonably well although I found the picture lacking in quality compared to other players. Simple and basic, and as such, may appeal to some.
Sounds exactly what newbies and other beginning streamers want and need. Once you find out how much fun streaming is, the learning curve goes on and on. What is important is to begin with a minimum of struggle
that site works on my pc. the problem is on an onn box. can someone else test it and see if HDO app is doing the same? I am in US and using spectrum internet. I will test it on my phone later
Edited later.. where is the link for the hexa app? cant find it on their website
yes.. thanks miki for the link.. was just trying to figure out if it was spectrum blocking the app.. update just tested on my hot spot with tmoble (mint Mobile) and same screen.. guess HDO got hacked?
Not for me. It works perfectly. Not sure where to go from here short of doing scans for malware and such. Spectrum may have blocked the site but I doubt it. Wait. Are you using a vpn? I always do and I tested out the site with mine on.
The app is listed in the starting tutorial but here ya go. https://hdo.app/tv
not using a vpn.. what country do you set vpn to? hdo.app/tv is where i always get the app… working on many boxes.. not running vpn.. let me test it with one
I use various countries depending on where the app servers are located. USA, Canada, Denmark mostly.
OK.. used a VPN.. tested like 6 different countries and it still gives me same error message. anyone else? connected to my cell hot spot.. same thing
all working good now.. guess just a glitch in the app
Had that happen when using hdo box. Now it’s just buffering…
I am thinking HDO app has bitten the dust,not working at all for me. Anyone else having issues?
I hope not this is my backup, although teatv still working for me as of last night. I use stremio but dad has issues with his ,like hdo. Trying to convince him stremio is way better by far. Harder time trying to get the VPN to work, Internet speed not all that great so much buffering. Oh boy the joys of tech and getting old.lol
The funny thing i jusy tested this app and there are no pictures of any of the movies or tv shows BUT they will play.
The HDO app crashes when you try to play anything. Have several boxes in different locations. Its crashing on them also. Hopefully there is an update/fix soon
Is this app working for anyone else? I have a couple of kin folk and this is their go to app. At first it was crashing. now after a reinstall install. It says no sources found for this show or something to that effect. Was just wondering if I should keep looking for a fix, or if it was down for everyone else also
Hey there, it isn’t working for us either. We suggest using an alternative from our top 5 here - 5 Best APKs for Firestick/Android TV (Free Movies & Shows)
And another one gone, and another one gone…another “Crap App” bites the dust!
(Queen)
Meanwhile KODI and Stremio remain the streaming Beasts!
