Having Trouble With Loop & Asgard
Can’t get Asgard to reload on my fire stick 4k max.
Also loop will not play since latest update.
Any help greatly appreciated
hi what update started the problem i have loop sport hd daddylive and rising tides on my stick all working but my main app is sportsfiretv
The loop has been updated to 4.0.
i have same 4.0 version all working try getting it from another source
Asgard when I input the apk instructions when I come to install it via the respiratory it says no network connection and do I still want to install I say yes but app doesn’t show.
Who do you suggest I get apk from please.:kissing_heart:
Only really use it for the live wrestling and replays of the wrestling.
https://loopaddon.uk/loop19/ try this source
Will try this loop and will let you know the outcome.:blush:
its where i loaded mine from any probs i will try an help some more
Does sport hd carry the options to watch the wrestling live plus replays.:blush::kissing_heart:
Just loaded the loop from the link you gave me and is working.
Just watching the rugby replay.
Just need to try and get Saturday night AEW Collision to play via no debrid version without getting a message coming up on screen saying check log for problem but previous week’s episode will play.
it has a listing for it but nothing playing at moment so does daddy live also if you know what channel its on i would think you will get it on sportsfire tv
Do you have apk instructions for sport’s hd please & when I have finished watching rugby can install them.
Sports first is a new one for men.,:blush:
https://team-crew.githhub.io/ for daddylive. https://bugatsinho.github.io/repo/ is for sports hd
Thank you…
Will let you know when I have installed them…, :slightly_smiling_face::slightly_smiling_face:
your very welcome :+1:
