Has anyone tried nextviptv.com . I have been using them and they have been great
Yes, I’m currently testing it on a 1-month sub. Seems pretty decent for the $…
Can you use it with tivimate, or only their chilltv app?
Are you using nextiptv’s app or TiviMate or Sparkle or another generic player?
I’m using it through my TiviMate app and it works like any other service.
I will say that yesterday their service went down, but I was quickly advised through their support system to change to a different URL which fixed it.
Yes you can
Nextviptv app is just tivimate. You just need to put your username and password. The app is call chill tv . Its free
Got it. I think that I didn’t ask my question very well.
What I was asking is whether they supplied xstream or m3u data to install into your own IPTV player. There are a few vendors that only allow using their own hard coded ‘app’…though the ‘apps’ are really modified TiviMate, IPTV Smarters, Smarters or XCIPTV.
So will they just give you the URL so that you’re not locked into using their version of TiviMate?
I wouldn’t want to use the free TiviMate version.
Yes that is correct you can use your own iptv player. Its just an option to use theirs
Yes that is correct you can use your own iptv player. Its just an option to use theirs.
Does anyone know what the difference between extreme and omega plans is?
Yes - It’s the amount of connections. Extreme is only one connection. With Omega you can get 2 or more for whatever lengths of time they offer. I have the Omega 6 months 3 connections for $40 bux U.S. works for me! Good Luck in your search.
I was wondering the same thing. I want to check out their service, but I don’t want to delete my tivimate.
Yes you can use any player that you want . Its just an option if you dont have a player you can use their chill tv app
yes it is one of my backups - works ok but nothing to send myself a letter about. May or may not renew depending on how it acts between now and then!
Is NexTV still active? I need to update the server address of the playlist I purchased back in January. How is the best way to contact them?
pm me please
i signed up when i tried to use my tivimate premium i entered my info tivimate accepted the user info but did not have any channelsor vod info so no playlist-i tried both urls given to me tivimate accepted both but no channes any help is appreciated
