I really like these cheapies more than the FS’s that we’ve had.
The only disadvantage that I’ve found is that they will overheat if using for 6 or 8 hours.
So I was wondering if any of y’all had successfully tried anything to mitigate the heat issue.
I’ve only had my running all day/evening once, because I have it as a backup…but in those 18 hrs of continuously being on but not always running…it never heated up to the point of it being a concern. These are a great alternative to heat sinks…available on amazon & ebay also…I learned about them from AMD.
Have you tried a small fan blowing on it? I have kept devices cool over the years with a small fan and even a 5 volt computer fan which you can salvage from a old computer or just buy one.
