Harmony hub based remote select button does not work on certain apps
My hub based harmony remotes select/ok button does not work on certain apps on my 2nd gen 4k max firestick. However, the firestick remote works perfectly. The harmony remote will open every app but doesn’t work on a few when inside the apps. An example of one of these apps is Defsquid. Does anyone know why this is happening? Thanks!
Can’t speak to your remote problems, I don’t think your having any. I think it’s the apps incompatibility with the new Max. I know Defsquid doesn’t work with it. Much better one’s out there.
I hear what you say but Defsquid works with the firestick remote but not the harmony remote. It’s really strange.
