H&I (Heroes & Icons) Channel - Mysterious problem
I normally use the H&I channel to view Have Gun Will Travel (Richard Boone) in the mornings and various Star Trek episodes in the evening. My streams are from Alibaba → M. Wu and Amber Baby. About two weeks ago, H&I stopped streaming on all of M.Wu’s servers. I tried several accounts with no change. I tried streams from Amber Baby and the H&I streams worked but the displayed programs were 3 hours behind what should be playing. The EPG correctly displayed the programs that should be airing. I have queried both suppliers and not received any reason for the lack of a channel stream or why the working stream was time shifted.
Has anyone experienced an issue with H&I?
It’s working fine on a service I checked. Correct EPG and current aired program. The problem is with their suppliers, nothing you can do. Just hope they read your text and fix it.
Sounds like a source problem where being three hours behind the west feed has replaced the east feed .
Thank you for the reply! The time shifted stream from Amber Baby now appears to have been corrected. Your reasoning was likely correct. Thank you again!:blush::+1:t3:
The feeds that were not streaming at all from Michael Wu are now all working!
I let both suppliers know of the problem 2 weeks ago. Their source is likely the same. I can’t complain given the very low cost for the high quality service!:blush::beer_mug:
I have the same problem watching H&I from Alivaba TV. The EPG is correct but the programs are wrong. I haven’t contacted anyone about this at Alibaba, hoping someone will notice it and fix it (also I can get H&I locally through an antenna so that helps too).
I contacted both Amber Baby and Michael Wu through the Alibaba chat and let them know of the problem when I had it. Amber Baby now uses WhatsApp for such conversations. The problem cleared after about a month for me. I have subsequently gone with Amber Baby’s $32 per year service and not had that problem re-occur. I still get buffering, time outs and voice not syncing but these transient problems cleared on their own or by switching a channel and returning to the channel that had the problem. This usually works with my service. I hope you have success! It can be frustrating. Still a good price for what you get. Stremio is worth using to supplement Tivimate.
