GSE IPTV for iPad Pro
Greetings,
I currently bought iPad Pro, and transferred all my apps from my old iPad, but for some reason my GSE app doesn’t support the Developers old app on my new iPad …looked for it on apple store, but doesn’t seem to be listed anyone using this app ? if not what would you recommend for new app ? Kinda liked that app :slight_smile:
Cheers,
Marko
I use “GSE SMART IPTV” works flawlessly on my Ipad Pro M1 12.9" and my IPhone 14 Pro Max :slight_smile:
Hi,
Yeah just download the new GSE IPTV unto my iPad Pro thx for the heads up
Cheers
I was reading your post. I had my MacBook Air repaired. I had IPTV GSE Pro. I can’t. get the the APP to work. It keeps rejecting and will not except the username and password. double checked all info and everything in the link is correct. I had this working before the fix. Looked at my System, Security and that seemed ok. Stopped my antivirus, did a Disk utility repair, up to date on the OS. Any suggestions would be appreciated. I know on the older MAC OS, you could allow third party software install. I’m thinking it could. be an Apple thing with the newer OS. Thank you.
try this if you have apple product >>> https://www.uhfapp.com/
