Suddenly Green Monster addon wont show any addons? Worked fine i guess ill reload kodi but i see the new beta still is unstable. Does anyone else use Green Monster sorry i mean build
You should use the search
and read what others have had issues with. Then you can contact those who use that build and see if they can help or even add your own questions to the threads you find. I found a bunch of posts about this Kodi build.
It’s in the Crew repo, so why don’t you just install the Crew instead, .
Yeah thanks to all i re installed kodi and green monster and so far working again. If all else fails you might as well start over its a good way to clear glitches
I have been using the green monster build on a Troy point 19.0 fork for a while. Now when I get on all of the addons say that there are errors.
Real debrid is current. Any idea what could be wrong?
Thanks in advance
I’m not familiar with that Build but most of the popular Addons have been optimized to run with KODI 20. I would think that the Dev by now would have a Build for 20. You might want to install the 20.2 Fork and do a Fresh Install of the Green Monster Build
Interesting response. It would have taken less time to respond , than inform me of a less than adequate forum that didnt know what i was saying
It isn’t the forum. I was giving you the shortest solution possible to get your answer, and that was to do a search for people, like yourself, who use the same builds and adons, and go to their threads to post your question. I was just trying to help, but if you think this forum is less than adequate you are certainly in the minority.
His response was a little short sighted. I thought Markxg answer was spot on. I guess hand holding is what is needed.
