Can someone tell me how to change the location for the weather in the upper left corner of the Green Monster build in Kodi 19? I have looked everywhere and no joy. Thanks
Probably in your skin settings somewhere.
The one place I did not check. I will check it out and let you know the outcome.
Found it, fixed. Thanks very much.
Where in the skin settings can you change the location for weather? I can’t find it.
