Got burned with 8k strong (iptvsubscription8k.com)
Subscribed to 8k (iptvsubscription8k.com) for 5 streams for an entire year back in December.
It worked with my TiviMate for about 1 month - then stopped working on all my devices.
I have not received any emails/notifications from iptvsubscription8k.com
One of my friends that also subscribed to them, told me that they made him purchase a specific app and was told that TiviMate was no longer supported.
Does anyone know what is going on with iptvsubscription8k.com
Sounds like they need to provide you with a new, working URL. Strong8k has had issues with portal URLs being shutdown. Your provider should be able to give you an updated one.
Too bad you didnt go with Amber Baby’s Strong 8K - She has always been really good about updating the server urls whenever one stops working.
Yes she has!
How does Amber communicate url changes? I am a new subscriber to Strong.
When your Strong URL stops working, here are some alternates…I don’t know how or IF she tells you. @MikeN will know.
She does not communicate them publicly but usually someone here posts the URL’s in this thread:
If you are having issues send her a DM on her Alibaba page and she will give you new URL’s if needed
When my Amber Baby sub stopped working, I reached out to her and she quickly gave me the new url that has worked since. URLs change in these all the time.
Have contacted your provider directly? If so, what was their reply?
Your service has been out for two months. If you paid by credit card, contact them and begin the process of getting your money back.
That’s the old list,
New
I am also having issues with the 8K strong. However, Abby has been working with me but we have not found a solution or a good URL as of yet. I have also tried the ones in this post by the other Patron They are not working right now either. Does anyone know how I can access the downloader? It says the web page has been removed. Any help would be appreciated. Thank you
@MikeN Thanks. I have updated the JPEG on my desktop to share when others need it.
Happy anniversary. 5 yrs a member and posting at last. Good to see.
1000018093
Are you looking to install downloader app?
Android - you will find it in playstore
I have the app however I can’t access the Troypoint tool box
250931 I believe is the code. Turn off your VPN (if you use one) and any ad blockers
Ask them for an update URL for TiviMate.
@mdjordan7 , HAPPY ANNIVERARY… :birthday_cake: :birthday_cake: :birthday_cake:
Me too, she has given me 5 extreme codes. As of right now I’m on the 3rd one that is working right now. It seems it works for about a day then fails. Conventional wisdom says that I can fix the failure 2 more times before I contact her again. I noticed someone mentioned Vortex? I’m having trouble locating the original certified site. Any suggestions is much appreciated :+1:
I am brand new to strong but I’m about at wits end. It works for a day and then quits. She sends a new url right away (thru alibaba email) but they are all having issues. She sent me 4 today and so far I’ve tried 3 and none work. What the heck is the problem. I’m using (trying to) tivimate. What a mess!
