Hi:
I recently discovered Stremio and, thanks to the good folks on this forum, am having a great time with it.
One question: I have Cinemata and Torrentio addons installed but sometimes get “No strems available, try another addon”.
What good community addons will complement Cinemata and Torrentio?
Thanks in advance.
I’m pretty sure I listed them to you already but here.
Cinemeta
Youtube
Watching
Public domain movies
Open subtitles
Local files
Torrentio
The pirate Bay
123 movies
Juan Carlos
Orion
The movie data base
Tmdb database
Cinemeta extend
The pirate Bay catalog
I’m loving stremio Also since I was finally able to enable my rd using the advice from Dracoo using more than my syncler now . I will be adding Orion soon and it will be even better. Great option to have thanks for everyone’s help with it
Awesome! Stremio is super fast finding links and is also one of the best free options. Orion works very good with stremio.
Hope these addons work well, I can get everything on them alone even without rd.
Thanks Dracoo. Quick question: what are the “local files” and the “databaase/catalog” addons?
Just more options to get torrents. The description on stremio tells you, they also add a function to the home page “discover” where you see top series and movies.
