“Getting No Links in Cinema HD” …GOOD!
I asked the question for you on filelinked/unlinked telegram forum. And asked for the ad free version of 2.6.0
Here is their reply.
https://rshor.tk/ygwez for 32 bit
https://rshor.tk/3d588 for 64 bit
Please note that i have not tested these links myself. I am passing on the information.
Edit: If you are not sure whether ypur device is 32 pr 64 bit, the app, aida64 will show you under " cpu".
Regards
Thank you for all your help! It is much appreciated. Good apps are hard to find.
FYI:
I installed and tested the new version you recommended and sent me. It worked fine and only had two false/positive VirusTotal results reported.
I Compared New TV shows and Old TV shows for Real-Debrid and free links in each app version.
The old version was an Analytics 2.5.0 [Beta Ad Free] from HiFi - (Clean on VirusTotal) The new version was 2.6.0
Surprisingly there was no difference in the amount/quality of links between both versions.
I was considering updating because recently I noticed a decrease in links. But it must have just been because of more holiday server use.
Now I know a good Cinema HD App will work for a long time. Not like some other apps that need to be constantly updated because the links disappear.
Glad to have helped. Be careful about updating, you might end up with adverts.
I suggest you back the app to your sd card. And then if you update and it is advert riddled, you can uninstall the updated app, and reinstall the previous one.
Enjoy🙏🏻
Update - IPVanish is now claiming that the constant buffering in cinema when the vpn is on is not their fault but instead is the fault of my isp, which is T-Mobile home internet. For the first couple of months I had this isp (which I have speeds of 250-300mbps on my network), I didn’t have any issues using my stick so I am not sure how IPVanish support can now be telling me that T-Mobile doesn’t work well with vpns. Any thoughts appreciated.
I’ve had the same issue and I believe it’s because no one is uploading content to the site. Plenty of Poster Art and portals, but no uploads. Same with Cyberflix which has even less content.
I took the recommendation from Troypoint and side loaded Onstream following the directions in the email and it couldn’t have been easier!
Great site! Plenty of current TV shows and Movies, you don’t need Real Debrid and I did not register, so I would be Anonymous. (Yes I have a VPN) No issues and great quality!
Watched bee and cinema yesterday no problem . Today no stream on either new or old shows know of any problems
Don’t use Bee but Cinema working here with RD.
Same issue here… Cinema is not working on any of my 3Firesticks?Signed into Real Debrid. Cleared Cache, Uninstalled, rebooted stick, hard and soft reboot, Changed players etc etc… Last night we got like 1 stream but I’m use to 30-40?? Fast internet, no issues.
Don’t know what version you’re on but I’m on 3.0.6
And using Buzz x5
Been working good till today using latest one from Troy point
Using latest one from Troy point. Was working great till today
What part of the country (USA)? are you in? Maybe it’s a server location? I’m using VPN, tried off and on… still no streams
Southeast
Hey Revav77!!! I just fixed mine… All I did was sign in to “Real Debrid” and I had a bunch of ‘downloads’ on there! 19 pages… I deleted them all and it’s working great!!! Try it… FYI, I’m also in the Southeast
After researching, the only suggestion I could find that might be causing no data, or streams, is to make sure to use the ad free version and turn off any ad blocker you have when using CinemaHD. Sometimes Cinema does go down for a couple of days as it doesn’t have a huge developer team and it gets overwhelmed with new users when some other apps get shut down. Hopefully this is the case and all will be good again soon.
Same thing here. Cube went down, long story, it pretty much factory reset itself!? Had to reinstall all my apps. Supposed latest version of cinema, icon looked weird and different, and no streams. Not to mention, i lost my whole library. Been using flix, successfully, trying to get me shows and movies, from memory, not so successfully.
Make a Trakt account so everything syncs to there. That way if you get a factory reset or equipment failure all your history and favorites are still available.
I don’t find Cinema HD very good because a lot of the streams are unavailable and a lot of them are incorrect streams when picking movies.
