As i asked you yesterday, " what version of Cinema HD are you using?
Have you tried the version i sent you?
delete
I would delete cinema and try stremio. Once setup it doesnt need anymore more tinkering with. Also start a fresh kodi and install fen and umbrella.
Give this a try.
i use cinema with real debrid and ip vanish and do not have any problemās with it ever. other than that i wish i could help you, good luck, hope some one can help youāāā
Thanks, until now I hadnāt had any problems either.
I believe it is 2.6, the one on Troypoint app recommended. It has been working fine for months and suddenly issues.
Perhaps try the ad free one link i sent you.
Good luck
Okay, I guess that answers my question, that maybe it is on RDs end.
The same thing happened to me and when I tried to update cinema⦠It said I had the latest version but I knew because of Troy point that it was supposed to be version 2.6
It turned out I had to uninstall cinema and reinstall it to get the two point six version and now everything works.
I did that and have 2.6 and it has issues. New twist - I decided to scroll down and pick random shows and apparently the sleezoid shows like Love After Lockup have RD links but none of the regular prime time shows do. Go figureš¤¬
Try rebooting your router. I use version 2.40 with no issues. You can also try backing out one time and then retry the links.
This works great with RD
Your problem could be your 2nd gen stick. I had issues with mine, not connecting right, losing apps etc. even if you keep the cache cleared it didnāt matter, your stick is obsolete. I went to a 4K max and all is well. There is one thing of note, if my VPN (IPV) is off, I canāt connect to anything including real debrid but once I activate my VPN, I can connect to everything. Just sayin.
Same happened to me. I went to realdebrid.com and my account showed that my 180 days had expired. Debris does not notify customers of accounts being defunct. I re paid my subscription and now works perfectly. I did have sone trouble with my credit card validating but called the number provided and they helped me through it.
Iāve been haviong the same issue with Cimena. And I jumped throught all the suggested hoops and still basically nothing. I got no RD links and only one link. And I guessing itās been a week to 1o days Iāve been trying. Iām an old fart and I donāt like change. But it looks like I have no choice.
Right there with you
Does Streamio work with Trakt? With IPVanish? Although I am having difficulty all of a sudden with IPVanish staying connected too. I have done everything they told me to do and it hasnāt helped.
My account is active until March
I would agree if it werenāt for the randomness of it working on one show and not the next.
