FX File Explorer Enable Write Access to USB Drive
Hi all, I’m having a problem with fx file explorer. How do I enable write access to a usb drive? I’m using a mecool km3. Any help would be great, thanks.
enable all permissions and/or try another manager.
Or even try cx explorer. Very easy to backup to SD card/external storage.
All permissions are enabled, still does not work. Also tried cx file explorer, same issue it says (tap ok to allow access to usb storage) when you do it says application not found.
Been researching and think this is a problem with android TV 10
More info…
Getting this error when trying to delete from the usb drive.
ES file explorer is the only one that works
