FUBO does not like a VPN being on
I use Surfshark VPN with my Firestick 4K Max and all is good execpt when I try to open FUBOTV. FUBO is my main viewing tab. But…It won’t run with a VPN on. I get a message stating to turn off the VPN so FUBO will run. Any help would be good.
Where are you located? Fubo has country restrictions. So you’ll need to use a server in the US. I think it’s only available in the US, Canada and Spain.
Fubu does not permit vpn’s, either turn it off or tunnel(bypass)
I’m in Nevada and my VPN is mostly set to Fremont, ca. I don’t know how to set the VPN for Tunneling.
I live in Nevada and my surfshark VPN is mostly set to Fremont, ca. I don’t know how to set the VPN for Tunneling.
in the surfshark settings>>>vpn settings>>>Bypasser and in bypass vpn, click fubo
SS brags it can bypass the fubo vpn issue, you need to test various server locations. I don’t have Fubo so can’t test this boast. gl2u
How to use Bypasser™ for Android – Surfshark Customer Support
Thanks, I will get it going.
Somehow lost it off my apps, have to find it and redownload it then follow you advice. Thanks
