My boyfriend bought a fully loaded freestream box at a fair and now Max app does not work. It wants credit Card info. What can I do? It is useless. Can I bypass the Max app so I can still use the Android box?
Sounds like the box software and operating system is closed and tied to the app. Nothing you can do, do not give them your info.
Never ever buy a preloaded box.
I purchased the same MAX TV Box. When I got it home, it would not work. I putzed with it and ended up bricking it. It sounds like you may have factory reset it. That’s what I did. I found that if you leave it on, it will reset back to where you can download the revised MAX software. If you go to the “Update”, there is a 9/17 build. Click on it and everything will reload. Also, Real-Debrid is a must for everything to work. Good luck as this worked for me.
