Free TiviMate Premium APK Mod
That’s the regular, non premium, Tivimate.
I had the older TV mate 2.8.0 mod loaded and programmed for my servers. I upgraded that with tvmate 5.1.0 mod that was programmed for one of the IPTV servers. And it worked. I am now on TV mate 5.1.0 with my servers. The only drawback is that I cannot add any new servers. To add servers I have to go back to 2.8.0 and start over.
There is one advantage to loading some of these branded TiViMate premium builds offered by your services. That is you are not using up the 5 device limit on your TiViMate subscription and can give one of them instead to a friend or family member.
does any one here have the latest modded 5.2.0 version from their iptv provider ,if yes can you share please
If you go read Troy’s latest “Unlinked” post, I’m certain you can find it in one of his best sites if you look around. .
here’s a modded version of tivimate 5.1.6 with all premium features unlocked…you can add it to as many devices as you’d like…scroll down to download
TiviMate Premium v5.1.6 APK [Latest] - HostAPK
This only works for one particular IPTV provider.
not true..you can add several playlist…i’ve tested it and it works fine
This site you linked will take you to a popup that says you have virus and to call Windows support. Best if you provide Downloader code. When i finally got the apk it was a modded apk for popular IPTV service.
Link took me straight to the modded apk download. Didn’t use it as I am a firm believer in supporting the Dev for TiVi and the lifetime works out to be very inexpensive.
You were able to download it?
Sec I’ll try it. Soon as it got 1/4 through Malwarebytes blocked the download saying it had an embedded Phishing link.
That’s probably the site it took me too that said to call Microsoft to get rid of virus.
I recommend everyone stay away from this site TiviMate Premium v5.1.6 APK [Latest] - HostAPK. Very deceiving when trying to download the apk.
Just buy the real Tivimate and hopefully the developer will keep it updated. The money saved easily justifies a purchase like this. Smarters or Sparkle are still a great options also.
I agree. Or use the modded one from the provider so you don’t have to worry about the server address changing.
I downloaded with no problem? do you know how to download files?
@Comtech
Was unable to download the file from your link. Got this dialog box.
Sometimes sites will block VPN, which I am always behind.
@Comtech should create a Downloader link or direct link as the site he posted takes you in circles trying to download the file.
i just downloaded again…scroll to bottom of first page and press the new link for newest one…it will take you to uploadrar page…then scroll to bottom and hit free download…just did it and downloaded with no problem…seems some peeps can’t read directions…lol
donot fall for the fake download link at top of page..go to bottom of each page and download…easy peasy
