Free TiviMate Premium APK Mod
i did a 1 month with kemo , works perfectly
So I tried this on a Firestick 4K Max with just Kodi and the Crew on it. Now I get “Error (404) We can’t find the page you’re looking for”. Go figure! Guess I really messed it up.
I just tried the 571859 code on a new Firestick with no VPN and also get the “Error (404) We can’t find the page you’re looking for”. Any thoughts?
I also loaded 571859 and got 404 cant find page. Vpn off and no other version of tvmate installed
K. reseller probably pulled the link.
Looks like dev’s dropbox limit was reached. You can get same exact app with Downloader code 2505227.
I had the same problem with Tivimate😏
I can confirm USB drives work with Sparkle with the Onn.4k Pro box, although it’s a pain to get it to work initially due to the Android version, there are plenty of resources to let you know how it’s done, and it’s worth it once it’s all working as it should be😉
It’s not same exact app!
Both downloader codes have had the same results for me. They will not load. This is on a 4K max Firestick with Kodi and just the Crew loaded on it. Oh well…
Would you please share a resource that shows how?
Sorry, that was their smarters app…here is proper code 2505227. If it doesn’t install you need to turn off vpn if using one as the site that is hosting this apk blocks som vpns.
welcome
Hello, if I need recording storage on Android TV, I just expand internal storage. See my video here how I do this.
this installs a modded tivimate but you cant add your own servers you have to use a server called tvtube?? doesnt even make sense, its unusable. since playlist is locked to something called tvtube
I go over all of that in the video.
Yeah, it actually does work…you just need to be using the proper service. Watch the video!
A post was merged into an existing topic: Walmart Onn 4K Pro Review & Guides
What has me scratching my head is why Troy would even bring this modded TiviMate to the forefront in the first place. Shouldn’t he be looking out for the developer and all the work he/she does on the best by far IPTV player? I’m disappointed in Troy’s move with this and think he should take down his post promoting this knock off and stick with the original. Just my thought. Homer
As I said in my Rumble video reply to this same comment…
If I really wanted people to use it, I would have shown the full-blown free APK that can installed. I chose to show the APK that is only available for Kemo subs and they already know about this because they are instructed to install it within their welcome email. Thanks for the comment.
The version that I showed doesn’t work with any other provider.
is this it?
https://www.apkmirror.com/apk/armobsoft-fze/tivimate-iptv-player/tivimate-iptv-player-5-1-6-release/
