Greetings,
Anyone purchased this device ? like to get some feedback if you have this device.
Greetings,
I will be buying it next year.
I was going to get the nvida, but not needed for my needs and it’s price.
The z10 pro max is upgraded z8 android 10-11 it’s a fantastic box and very underrated.
I own the z8 pro and had it over a year with zero issues. I can run practically anything on the z8 without fault.
Not a baised review the fourmler has its down sides but nothing really jumped out. The one thing that bugs me is that it’s a semi closed box which means I won’t be able to have a custom rom and rooted Because of mytvonline2 but you can use any iptv player without issues.
The z10 pro max has upgraded hardware decoders for av1 and others btw.
Thanks for the Feedback I’ve had the z8 for a least over a year and gave it my GF she really the interface and MOL2 app, this xmas I’m going to get the z10 max pro maybe over kill, but there reputation stands for it’s a TV box
Regards,
Marko
PS Merry Christmas to everyone and stay safe
Side note you can install other iptv players on the box, they work well too.
Mytvonline2 does do m3u and extreme codes.
You might be able to install an apk called King Root on your device to establish a root for your box. I believe there is a utube video for this that you can check out.
Yes you can, but the fourmler boxes are semi closed and because of that I’m sure it will fail.
