Formuler Z10 Pro Max Android TV Box First Impressions
There are alternatives and there are equivalents. I personally don’t think anything is Tivimate’s equivalent, but there is a lot of IPTV software that tries to be. I’m sure it is fine if you aren’t spoiled rotten from previously using Tivimate lol. As far as getting it to iOS, I know almost nothing about iOS, but I would think you may be able to find the .apk file and get it loaded?
It’s a great player. You can create your own categories. Two things I haven’t found and don’t think you can do are customize colors and put the time in corner. I know those are petty things so it doesn’t bother me because I really like it
I used an iphone for 1 day and took it back. The kid said I figured id see you again…I said really?..he said I knew you had been a long time android guy and the iphone was another world…I said you were right, wish you told me that yesterday…he said he wasnt allowed to tell me :thinking:
Cannot get it (Tivimate) to iOS at all, as it’s android so it is not compatible. That’s why I was asking about myTVonLine that you mentioned…
When i said .apk I meant for the mytvonline…but since I am unfamiliar with iOS i’m not sure exactly how you could get it loaded onto the Apple box. His 4k Firestick should be fine for either option I would think.
Yes, so his 4K Firestick is the device that will be used. Apple devices aside. I would love to give him a solid alternative to Tivimate, but it doesn’t sound like the other players can come close enough in stability, quality, customization. If anyone feels this isn’t right, and can recommend an IPTV player option (sub required or not), I’d love to hear it, and how to load. Thanks in advance!:slight_smile:
