Am i able to format my usb drive to fat32 using a ipad? I dont own a laptop or desktop. Thanks
Can’t be done on iOS.
With ios 13/14 it can read usb or half support it. I believe Apple made changes to support but only if it is in fat32 already I believe.
But to formate you need the utility drive on Mac os. Can’t be done.
Anyway Jay is right. I donno why I posted sorry.
It can be formatted through the new firestick 4kmax correct?
I would guess so. I haven’t seen anyone report that it doesn’t work on the stock OS. If you’re just formatting it as external storage you should get a prompt as soon as you plug it in. If formatting as internal then follow the TP guide.
