I tried adding Troypoint toolbox in my favorites on downloader. always get an error: forbidden. l reloaded downloader, cleared the data and cache in app settingsl. I am using a nvidia shield pro.
Not sure what to say. I use the shield and just did what you are attempting without issue. Only thing I can think of is to go to settings a nd make sure everything is check marked.
Turned on my vpn problem solved also forgot to mention I am in Mexico for the winter. Must have been the problem, anyway thanks for the reply
Say hello to Miki down there!
