FireTV Question
I have two Firetv’s and if this question has already been answered, my apologies for the redundancy.
Question: Does anyone know how to copy favorites (Movies and TV programs) on one FireTV and sync with a second FireTV?
Thanks
I don’t know of a way to sync automatically, but you can install a file program like “X-plore”, which will display two panes. One side will be your source Fire TV, and the other, your destination Fire TV. That way you can transfer the files you want. This program works across your network, so if you can see both FireTVs on your network, using this app, you should be able to transfer files between the two Fire TVs.
Transfer but not copy?
You can do either one. Transfer to other, or copy to other.
Sounds like Trakt.tv may be worth exploring for ya. A lot of the APK’s can be setup using it, so just verify if its available via your “settings” menu. If so, then you just need to create a free account. It’s pretty cool as it updates instantaneously, so any device setup using the same account is as well. Here’s Troy’s guide: Trakt TV on Kodi & Streaming Apps - Sync Your Shows and Movies
I’m trying to transfer files from firestick storage to USB with x-plore. It shows the files are moved, but the only thing being transfered to the USB are the APK files. It still shows the app (in x-plore) in the left panel and the APK on the right. I’m not gaining any space on firestick storage after the transfers.
Could really use some help with this.
Welcome @Tlhicks713!
I haven’t used xplorer in a while. But when you select to move the file did it ask you if you wanted to delete the file source? Or something similar to that.
You may be only copying to file and not deleting from your firestick.
The apk is the android package kit that has the app inside.
Someone else can explain it better but thats my understanding.
So dont delete your apps just yet. Wait for a confirmation from someone more knowledgeable. There are lots around here.
