I trust the skills and knowledge of all members here. With this being said, are users moving away from the FireStick to ONN and other devices? Is there a ranking of the devices that members are currently using. I need to get two new devices to expand usage into spare rooms in my house. Thanks in advance for feedback.
Personally I dumped all my Fire TV devices (4 of them) over a year ago and went with the ONN 4K Pro’s. For the price point and performance I highly recommend them. I also have a Nvidia that’s 3 years years old, no complaints other than I think it’s way over priced. It really doesn’t work that much better than the ONN products. Just my opinion…![]()
While they are great to have, I don’t really have a need (yet) for the “high-end” boxes like NVidea Shield, Ugoos SK1, or Formuler Z11 Pro Max (not to mention some of the others that cost considerably more than these) because I’m not taking advantage of the many things these boxes can do (all that may change as I move in the realm of true IPTV, coming very soon). So, if you had a Firestick and that met all your needs, you’ll absolutely love the Onn devices - I’ve got the 2nd Gen 4K Pro. It’s a pretty easy transition, almost seamless!
And while we’re on the subject, if anyone out there feels that I be better off with something else for IPTV, let me know what that is, and why!! Thanx!
If you’re just using it for iptv an onn box is more then you’ll ever need.
I’ve been using the Onn box pro the last two years. And recently my local Walmart had a few of the new Onn pro v2 boxes so I picked up two of them hem on Friday
For what it’s worth, I’ve tired of the shenanigans. Have moved to Superbox in all my rooms now. Yes expensive for the front outlay, but when I consider what I’ve saved over the years, its a nothing-burger. No ongoing costs, unending live TV and sports and all the movies and series I would want.
Thanks and your position seems very logical. Can you give me more details and the sources for this product conideration? What does it provide to you as a user?
In the US you can buy directly from Superbox. In Canada you can buy them from Walmart. There’s a little bit of setup but instructions are included, and certainly if you have ever programmed up a firestick or onnbox it’s easy peasy.
Once you purchase a SuperBox, I recommend joining one of the FaceBook groups. If there is an service issue, this is usually where you’ll find a post regarding that.
i dumped my firestick too i have an x88pro13 4gb ram 64gb rom i like it a lot better then the firestick,i still have some problems getting the errors and such so i keep looking for help making sure i set it up correctly
I’m still using my old Firesticks. Not a problem at all
@chenry2545 ditto here ![]()
